Is this enough?
I recently purchased the DX3.0 DSM 3CH is this going to be good enough to turn my Warhead?
1-Z270 Standard Race Servo 1-Z590 Hi-Torque Race Servo |
RE: Is this enough?
I'd use the Z590 for the throttle and get a stronger servo for steering. 85 oz is a little weak for steering on a MT.
RE: Is this enough?
What would you suggest?
RE: Is this enough?
Go with the Hi Tec 5955TG servo. 333oz of whipass!! All you will ever need. It's a little pricy, but it's like tires, one of things that make a huge difference.
RE: Is this enough?
ORIGINAL: theodore.scott1 Go with the Hi Tec 5955TG servo. 333oz of whipass!! All you will ever need. It's a little pricy, but it's like tires, one of things that make a huge difference. |
RE: Is this enough?
I use a Hitec 5645MG , I forget the specs but it turns my REVO's steering no problem and is pretty quick too . Cost me like 50.00 at the LHS .....
RE: Is this enough?
If you have a good battery pack the HS 5645MG pretty good choice. At 6 volts it kicks down 168 oz of torque and 143 at 4.8 volts. If your using a plain battery or a 1000Mah rechargable your better of using an analog rather than digital servo......which is the HS 645 MG that works out at 6 volts 133 oz and 107 oz at 4.8. Not great but not bad either..........Analog the batteries last a lot longer and the servo is a lot cheaper. My self I run Airtronics Bone crushers and I don't even like to think about the price[:-]
RE: Is this enough?
ORIGINAL: rclynx If you have a good battery pack the HS 5645MG pretty good choice. At 6 volts it kicks down 168 oz of torque and 143 at 4.8 volts. If your using a plain battery or a 1000Mah rechargable your better of using an analog rather than digital servo......which is the HS 645 MG that works out at 6 volts 133 oz and 107 oz at 4.8. Not great but not bad either..........Analog the batteries last a lot longer and the servo is a lot cheaper. My self I run Airtronics Bone crushers and I don't even like to think about the price[:-] |
RE: Is this enough?
No I said don't like to think about it................LOL
| All times are GMT -8. The time now is 09:57 PM. |
