Servo Saver Question?
I'm using a Hitec645 for throttle/brake I know it's overkill but I had it so I'm using it.The carb is not opening all the way and my servo saver is not strong enough to open it.Is there anyway to make the stock one stronger so I can get full throttle.I'm using a throttle return spring too but even with it off it still doesn't open all the way.
I dont know if you have allready tried this but I did what another post told me to do. I saw it here or somewhere???? I just squeezed the spring in the servo saver together, its fun putting it back together, but it worked with mine. You could also use the one on your steering(I heard) and just get a better one for your steering.
Sweet thanks allot i'll try the steering one since I changed it to a kimbrough one and its just sittin here.(now if I could just remember where I put that thing)
I think the one for the steering may be to stiff.The engine is moveing when I hit the break now but the carb is opening all the way.
try taking one of the springs out I believe theres a steel one and a plastic one, been a while since i've had mine apart,
