new crank shaft
when u get a new crank shaft do u have to go through the break in process again?
RE: new crank shaft
You should be easy on the engine anytime an internal change is made.
Can I ask why you are replacing a Crankshaft? |
RE: new crank shaft
The break in is mainly for the piston and sleeve to fit together properly. The only thing with a new crank would be how the bushing in the rod fits on the crank. I would take it easy for the 1st tank and then you should be ok to run it like normal.
RE: new crank shaft
NO [:-]
