Engine issue
I noticed on my tmaxx 3.3 that when i get it tuned right (it seems to be right), and i make a high speed pass it kinda "purrs" when the engine is slowing down. is this normal?
RE: Engine issue
If you mean that it takes a millisecond for the RPM do drop after you let of the gas, then yes, that is normal. If it takes a few seconds, then you are getting something called "run-on" which is were you have the low end needle set to rich. The fix, lean the low speed needle a little bit.
Hope I helped. Warheadforever |
| All times are GMT -8. The time now is 03:57 PM. |
