monster truck with a starterbox
Just as the title states Is there any that can accept a starter box?
RE: monster truck with a starterbox
The old ofna monster pirate, and dominators could i believe. They were good trucks based on a buggy driveline.
I dont really know of any others that do though. Eric |
All you need to do on most models is put on a larger flywheel and have an engine flush chassis AKA flat chassis. Not sure about others but the XTM comes stock with a 37mm flywheel but if you want to use a starter box they stock a 39mm flywheel or there are even larger flywheels by other manufacturers. Second choice is to shave the motor mounts to get the flywheel close enough to use the starter box :D
Only one i know that can do it, out of the box is the revo.
Other than that every other mt, needs a different chassis. |
revo and duratrax warhead
