Pats Brakes
Pats Brakes
Hey guys if your looking for the best you can buy Pats Brakes are the way to go. These brakeswill actuallylock the wheels up with the least amount of servo pull. You do not need high end servo's to pull your brakes with Pats Brakes and Gotnitro.com has got-em IN STOCK!
www.shop.gotnitroonline.com/main.sc
Pats Brakes Single Set Front or Rear. This Brake Set will fit front or rear nitro or electric bikes. You can run single or dual sets on the front or rear. For nitro bikes we recomend dual front and single rear so you need 3 sets (Special Pricing). For the electric bikes we recommend dual front sets (Special Pricing). The more sets you buy the more you save. Complete with stainless steel cables inner and out sheath with crimped end. Over 140lbs of breaking stain on these cables. The brakes fit the alloy one piece rims front and rear and rear 3 piece rim. Will not fit the 3 piece NF Front Rim. This is a single complete 6061 T6 Aluminum Set for front or rear Electric or Nitro Bikes. Comes complete with GRP pads same stuff circuit boards are made of. these pads are replaceable. Comes complete with Single Front or Rear Rotors with Fiberglass Pads, Calipers, Mounting Brackets, Nuts and Bolts and Stainless Cables with crimped ends and stainless steel sheaths. The Brake Cables are constructed with a sheath consisting of wound stainless steel. These brakes do not need monster servo's the 3.3kg/cm servo's pulls the nitro and electric brakes just perfect. Only brakes on the market that actually will lock up the wheels. Probably the most sought after brakes for RC Motorcycles in the World. Perfectly machined All T6 6061 Aluminum pieces we are proud to be offering these to our customers. Best possible braking money can buy period. Shipping is absolutly FREE on this item. Front Rotor: 50.5mm Wide Rear Rotor: 45mm Wide Complete set of instructions included! Beautiful Workmanship!
