RC Motorcycles Discuss RC Motorcycles here
need a chopper bike!!!
Old 05-30-2004, 08:53 PM
Q8 RC's Avatar
Default need a chopper bike!!!
1/8 Nitro Chopper - Drag Motorcycle
All you chopper fans get ready, this scale radio controlled "nitro" chopper isn't just for looks. The bottom of the bike is a cnc machined aluminum plate for mounting the engine and other goodies. The forks are spring loaded. It has a hard tail rear suspension. Built on a powder coated heli-arc welded, 4130 chrome moly tubular steel chassis it takes realism to a new level with high quality detailing and a lexan body, including seat, tank ,front and rear fenders and sign boards for the wheelie bar. A properly designed and engineered drive train provides great performance and durability. Included in this kit:
Drag Motorcycle is breaking all the rules. A properly designed and engineered drive train provides great performance and durability.
This Chopper will go over 65MPH!
Billet aluminum front wheel with rubber tire
Billet aluminum rear wheel and foam tire
Header and pipe to fit side exhaust engines
Clear Lexan Body (six pieces)
Wheelie Bar
Servo mounts and linkage
Plastic fuel tank
A single speed transmission
High performance clutch
Full Ball Bearings
Front headlight and bracket
Length: 22.0"
Height: 7"
Width: 4.5"
Wheelbase: 11"
Weight: 3lb 8oz with radio
What you see below is the complete bike with engine (not included) and custom paint job:
its 499.99$ at www.RC4WD.com w/o engine and radio (KIT ONLY)
Note: To run this chopper, you will need an engine (fit most .12-.18 nitro engine), radio, servo, battery. And lexan body require paint job
ID:	137887   Click image for larger version
ID:	137888   Click image for larger version
ID:	137889   Click image for larger version
Old 05-30-2004, 09:00 PM
Q8 RC's Avatar
Default RE: need a chopper bike!!!
some more pics:
1-Aluminum Fuel Tank for Chopper Motorcycle
CNC machined aircraft aluminum
Super high quality finish
2-Handle Bar Grips & Tank Cap for Nitro Chopper
ID:	137891   Click image for larger version
ID:	137892   Click image for larger version
ID:	137893   Click image for larger version
Old 05-31-2004, 08:55 PM
Dr.ArmoMaxx's Avatar
old news [8D]
Old 06-01-2004, 04:21 AM
Q8 RC's Avatar
thanx for reminding me doh!!!!!
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
