RC Motorcycles Discuss RC Motorcycles here
Kyosho HOR
Old 03-31-2009, 08:46 PM
casper975
My Feedback: (18)
Default Kyosho HOR
Hi I just picked up a new Suzuki HOR and I noticed that there is a weight that go's inside the front tire and I want to turn it in to a wheely monster do I need to remove this weight in order for it to do wheelies or will it not balance with out it
Old 04-08-2009, 07:05 PM
popdada
Default RE: Kyosho HOR
won't balance, I think that's what keeps the front wheel straight
Old 04-09-2009, 10:53 AM
rcktpwrd
rcktpwrd's Avatar
Kyosho used to sell an optional light weight front wheel weight, not sure if they still do. There are usually a bunch of parts on Ebay for these bikes.
Old 04-20-2009, 03:22 PM
ASSOCIATED_DRIVER
ASSOCIATED_DRIVER's Avatar
I got the front light wheel weight and the high grip wheel set from ebay.
On the stock white rims, there holes to screw the wheel weights, but not on the black high grip wheel set. Is that normal.
How do you secure the wheel weights?
Do you also need to put foam inserts if using the stock wheels and tires? (Because the high grip wheel set came with it? (Maybe that's why there is no need for screws)
Old 05-12-2009, 06:10 PM
SnSHampton
SnSHampton's Avatar
I read on some forum somewhere that you want to use the foam inserts.They have said that u should use harder foam,that the foam that comes with the set of tires is to soft.
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
