nitro problem NEED HELP!
ORIGINAL: nitrostam
my friend had this problem and we ended up heating the header with a tourch and flaring the end a bit
ORIGINAL: rc awesome
The exhaust coupler will not stay on no mater what i do. i went to my LHS and they made a makeshift connecter between the connecter and the pipe. that seemed to work for a while, but i accdentally flipped the truck and the pipe came off. now it will not stay on. could i put some type of silicone in between the two parts. thanks
Banned
i'll post a picturee as soon as i get the chance. righ now i have it riged with a rubber band pulling the coupler in. the coupler just seems to short. i'll probably just order another one. right now the set up seems to be working; every thing is sealing nicely. BTW i've got new fuel lines, and a new hot glow plug hpoefully it will run better. it is the stock exhaust. thanks.well ran it and it doesn't work again. the guy at the hobbie shop buys rc cars so, thats were im going tomorow. good bye POS.
NC
where the pipe connects to the pipe. I put some silicone on so it think that it will stay. its at the shop, hopefully getting fixed. If it doesn't work when it gets back i will get a motor.
ok so first what you should do is take the glow plug out and take out the rings that should be inside,there should be a way to look in the motor ifyou shine a flash light in it and there are seals that could be busted if that is your problem your looking at paying any where from 50-80 dollars to get them replaced or get a new motor........................ or you can take it in where you got it and pay 5-8 dollars for them to check for anything.
Hope it helped!
Hope it helped!
NC
ORIGINAL: nitro engine
Hope it helped!
Hope it helped!
#32
NC
i just got done running it. it is defintally tuned better, but tif i go from idle to WOT it dies. To get it to run at WOT i have to go to half then go to WOT. i was also doing some dounguts and after about three seconds of WOT during the dounguts it would start to bog. The guy that worked on it had no clue why it was doing this, and i don't eather. please don't tell me that there is nothing that i can, do because if really want to be able to push the throtle trigger to WOT when ever i want
#33
I would turn your high speed neeedle counter clock wise 1/16 of a turn. Then run it for a few minutes to let everything settle and see if it runs better or worse. I guess that it will run better keep going untill your happy. But remember to do very small movements at a time and run it for a couple of miutes to let the new adjustments make there way
#34
NC
ok, i guess i will keep fiddling with it. Are these engines nortoursly hard to tune. Everone else seems to have a really good time with the nitro sport except me. The hobby guy said that that was probably the best that i would be able get it running. so far it's slogan : Fast, easy , fun has been a complete lie, expecially the "fun", and "easy" part. Well im really sick of it, and im about ready to give up. its never run right.
#35
NC
do you think that it has something to do with the temapture. is starting to dip in to the teens do you think that i should put a sock over the motor
#36
ok, i guess i will keep fiddling with it. Are these engines nortoursly hard to tune. Everone else seems to have a really good time with the nitro sport except me. The hobby guy said that that was probably the best that i would be able get it running. so far it's slogan : Fast, easy , fun has been a complete lie, expecially the ''fun'', and ''easy'' part. Well im really sick of it, and im about ready to give up. its never run right.
#37
NC
Well i won't be able to take a video because the motor has stoped running. I think that the slipper clutch is broken because if i set the truck on the ground wile idling it stops runnin. Oh yeah and the EZ start has stoped working completly. The guy that looked at it has been in RC for like 15 years or somethng like that, so i think that he knew what he was doing. I'll probably just sell this thing, maybe save up and buy an HPI firestorm or something other than a nitro sport. It was running really good, and then this happend. What do you think would be a fair price for me to sell this for?
