RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
XXX-NT trouble!! Help!!
Old 12-04-2003, 04:35 PM
underglow
Default XXX-NT trouble!! Help!!
I just got a used xxx-nt adam drake from a guy used. There has only been around 4 tanks run through it though. But when I turn the controller on I see the light come on then I try to turn the car on and the servo twitches a bit but then I press the throttle trigger or the steering wheel and nothing happens. I have changed the batterys and everything, what could be wrong?? Please help me, any suggestions welcome.
Old 12-04-2003, 04:50 PM
Nitroaddict
Nitroaddict's Avatar
Default RE: XXX-NT trouble!! Help!!
check the crystal in the receiver. your comments explain what usually happens when a rcvr crystal comes out of the receiver.
Old 12-04-2003, 05:02 PM
underglow
Ok, thanks for the suggestioin, I will try it right now.
Old 12-04-2003, 05:11 PM
underglow
I just tried it and it still doenst work, any other suggestions. I really want to drive this before it gets dark.
Old 12-04-2003, 05:16 PM
Nitroaddict
if you operate the TX and it doesnt move the servos, and nothing has gotten wet, than it has to be either power or frequency.
First - turn the TX off. then turn the rcvr on and off, see if the servos wiggle or anything moves. if so, then u know the batts are good. if not, then it is a batt problem. If the batts are ok, then its a crystal problem. u may need to replace a crystal. check the batts first though. could also be a wiring problem between the batt pack and the rcvr or switch harness.
Old 12-04-2003, 05:19 PM
underglow
Yes, the servo moves a little bit, not much though. And also on the reciever I cant even get the crystal out. But I guess I will take it to my lhs and ask them. Ok, well thanks, if you have any other sugg. let me know.
Old 12-04-2003, 05:23 PM
underglow
I just tried it without the switch so I bypassed the switch and it still didnt work so it cant be that.
Old 12-04-2003, 05:42 PM
scale only 4 me
My Feedback: (158)
scale only 4 me's Avatar
if they both have power, it sounds like they are on diffrent channels, check that the frequency #s are the same
Old 12-04-2003, 06:51 PM
Nitroaddict
if u are getting "servo twitch" then u are getting power and that leads me to believe its a crystal issue. if u are unfamiliar with how crystals work, take it to ur lhs and have them take a look at it for u
Old 12-04-2003, 08:33 PM
underglow
Yes, I was messing with it earlier and finally noticed that the frequencies where different. So I went and bought a whole new radio and reciever and servos. Thanks guys.
Old 12-05-2003, 09:37 AM
TheQuakeKing
My Feedback: (23)
Jeez dude! all you needed was a set of crytstals that cost $5!!
Old 12-05-2003, 07:07 PM
underglow
No I didnt, the frequencies between the radio and reciever were different and he said it would cost 30 bucks for a new reciever or 50 for a whole set of everything.
Old 12-06-2003, 08:38 PM
TheQuakeKing
My Feedback: (23)
Oh i didn't know their were set frequencies. Mmmmm. a first.
Old 12-07-2003, 08:42 PM
xtremerc2003
yea i bet it is the frequency
Old 12-07-2003, 08:46 PM
whitexj
well there a bit more than 5 bucks though.
