what is the best hop up for a xxx-nt?
OH
RE: what is the best hop up for a xxx-nt?
ORIGINAL: Mxracer45
That was definetely uncalled for
ORIGINAL: GT-Power
a RC10GT
a RC10GT
rrp aluminum diff gear, aluminum hubs, knuckles, pivot blocks, top shaft, titanium front axles, ah heck anything that they make in titanium is good, a good engine, good set of tires or 2 or 10, graphite suspencion parts all around, along with spares, a spare body for when your not just bashing around, 2 good servos, a failsafe, stainless screw kit, titanium hinge pins, kevlar spur gears. did i miss anything? oh ya and a good pipe and header.
Yup the RRP diff gear is probably the #1 upgrade. Then get yourself the updated differential screw and nut if you have the older one, also get the newer gas tank w/ the pressure inlet on the lid if you have the older one, the RPM front bumper, rpm ball cups.
