RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Need HELP! please
Old 07-04-2006 | 03:10 PM
Default Need HELP! please
hey guys i really need help [:@] i was going to use my rustler and i plug in the e-z start and start it up full tank of gas, use it for like 30 secs then hold the brake and i had to get something behind me when i was going to give it gas the engine cut out, because i didnt apply any gas for a long period of time. so then i went and got the e-z start pluged it in and tried to start it. it dosent so i thoguht hmm it might be the engine is flooded? so i did the steps to clear it out some gas did come out, put it all back together, tried it again no go..
so i deflooded it again little gas came out. i sprayed into the glow plug hole with some wd-40 like they say to in the book and cranked it over, to clean it. so then i try it again still nothing... so i took off the hose that goes to the carb from the tank and that was clear and had gas in it so i put that back in.
when i was spining the car around i tiped it so the exaust pipe and some gas came put , or liquid , so i cleaned that out and tried it again... still nothing!?
any ideas on whats wrong?
thxs
Old 07-04-2006 | 05:11 PM
Default RE: Need HELP! please
Have you tried replacing your fuel lines this is usualy a good way to start looking for a problem as yours. Also make sure your glowplug driver is charged!!!
Old 07-04-2006 | 05:35 PM
jandb917's Avatar
also make sure your glo plug itself is not bad to check it just put it in your glo stick is should turn bright red or white depending on the plug type
Old 07-04-2006 | 06:15 PM
ok ill cheak them
hmm i think the glow plug might be bad... ill have to try a new one [:@]
Old 07-04-2006 | 08:03 PM
try heating the engine with a heat gun before you try to start it. also make sure your batery on the truck are good it happened to me before i had bad batery on my truck and it will nah start. that all i can think of now IM a new so take advice from the exp guys first
Old 07-04-2006 | 09:16 PM
well when i plug in the ez start and if i have the glow plug out of the engine but still ploged in it should get red hot right? beceause it wasnt >.<
Old 07-05-2006 | 09:46 AM
Do the same thing with a new/other glowplug and if it still does not glow try to charge your glowplug driver.... if it has been fully garged and you are sure it has been chaged and still does not work you'll have to replace your "driver"
