Official Traxxas Nitro Sport Thread!!
#251
RE: Official Traxxas Nitro Sport Thread!!
Hey guys, well I put that heli on the shelf and just ordered this lil truck. I have been reading through the forums and see some things that need upgrading. Any ideas on good suppliers for these upgrades in the USA? or should I just hit the LHS.
#252
Hay there Duke I have an OS CVRX .18 here in a box i was thinking about puting in my sport. have a you got any pics of the mounting brackets you used ?? or are they shop brought ones?
How did u get on with the pull starter hitting the base of the chassis. or is that to much power for this rigg ?
Cheers Jason
Cheers Jason
#254
Yeah man, all i had to do was gring the mount a bit, it wasent that hard to install it. And the Pullstart fits fine. It has ALOT of power, lol, hard to keep the wheels on the ground, like i said, tore my transmission to bits. just losen the slipper and itll be fine i guess :P
#255
I bought a Nitro Sport about a month ago, I've run in the engine and tuned the car. - But no matter what I do, the engine always overheats and stalls. I've got a hole in the windshield, I'm using 16% Fuel. An help on ths this would be very appreciated.
Thanks in advance.
Thanks in advance.
#256
Possibly too late and youve already cooked it, but your running too lean, give the high speed needle a good half turn anti clockwise.. Should help ya out!
#257
I was doing the same thing till I realized that it has to be a lot richer than I thought as specially after is gets more run in .
I started on 2 & 1/4 turns out which samed to be right at first but as I got thru about 8 tanks of gas or more it started cutting out even though the tuning sounded right to me.
try 3 turns out and you may find that it is harder to get going to start with , it burbbles a lot more when cold but you need to do a few high speed passes untill the motor clears and revs out to top speed.
even then try to go slightly richer then you would like to , its better for the engine it will run cooler, after you get a couple of litres thru it it will go like a rocket , at lease thats what happened to mine.
I can always tell its spot on cause it does 20 foot long wheelies off only a slightess bump on the grass. also order some good back tyres the first ones will be worn out in no time beleive me! lol
Cheers Jas
Cheers Jas
#258
Thanks for the comments, firstly, If I have cooked it, can I repair it? Secondly, I've been running the car really rich and it still overheats. Is there anything else I can do?
Thanks guys
Thanks guys
#259
If it has been cooked good and proper, your better off buying a TRX 2.5R and replacing the tired old pro.15.. Iv got a 2.5R ready for when my pro.15 gives up on things.. You can buy rebuild kits, but its not really worth it for that motor.. Dont get me wrong, I love the pro.15! Its just a waste of $$ when you can upgrade for a little more..
Also, what makes you think your running it rich? Any chance of a vid?? Next time you run it, make sure theres heaps of blue smoke, not just a little bit lol, heaps of it!! And lets us know what happens!
#260
How did u get on with getting fuel ?
I got some pink 20% stuff goes good , when u going to line me up at the boat ramp ? I ready now before a break it again lol
jas 0274 540908 text for a race if ur keen
#261
PA
could you guys help me i have had my nitro sport se for 3 year and engine has sesed up should i just get a new .15 engine or get somthing better and if so what should i get for under $110.00
#262
I've been running it really rich, it bogs down sometimes and the smoke is pouring out - and still it overheats.
#264
you sure you have 18% oil in the fuel ??
is it the right stuff
without the glow plug in can u turn the motor freely by hand after it is hot , or only cold ??
Sounds serious !
Better break out the wallet !
Sounds serious !
#265
PA
#266
An O.S Max 18CV-RX 11G is a quality motor you would have to loose the EZ start though
Fit with some cutting to the chassis I am told
#267
in reply to...
________
You could upgrade to a 2.5 engine (kit) for around $150 US. Or maybe get a rebuild kit (sleeve and piston) for the .15 - around $50 US
Have you checked to see if it's just flooded?
________
#270
yer mate i know exactly wat the issue is. Take your fuel line and run it direct to the carb not arround the cooling head TRUST ME thats the problem
#271
ORIGINAL: nitro_
#272
ORIGINAL: Jason955i
#273
Well, I've richened up the mix by another 1.5 turns. I took it for a run today althought I only had 1.5 tanks of juice. The car ran pretty sluggish at first but after a couple of high speed runs it smoothed out. I got through 1 tank before it stopped, It felt fairly hot, so I waited 10 mins and richen up the mix again, once again it ran a bit sluggish at the start but smoothened out again - then I ran out of fuel.
I'm also now going to redirect the fuel line so it does not run around the head - this also should help.
thanks guys for the comments, I think I am well on the way to getting the car to run correctly without overheatin'.
#275
Thankyou exactly what I said ,Although the boiling fuel in the line is the main cause I had already rerouted the fuel line by adding a filter and another section of pipe around the front shock tower so its quite long , this gives it a longer running time when its upside down after a crash. you will always need to start off as if it is too rich untill you can give it the boot.
