RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
How to: Lock the Jato into 2nd
Old 01-25-2009, 01:57 PM
Wild YFZ 450's Avatar
Default How to: Lock the Jato into 2nd
Here it is.. How to lock a Jato Transmission into 2nd gear.. I will be showing the "Pin method" There is a few others though..
First step is take apart the transmission and the "Centrifical clutch piece..Should look like this
Next you can drill 1 or 2 holes for the Pins..Make sure you go far out enough so it doesn't get in the way of the Bearing and so the gear is the thickest on the outside.. Just make sure you don't drill through it.. You can even use the bearing as a guidelin..You can drill either one or 2 I used only 1 since I am using 1/8 wheel pins..It should fit snug...
Then put the gears back in. Remember you can Take out the first gear so it will be less rotating mass.. Just make sure you keep the one way bearing in there as the spacer...
then slap it all together..
Throw in you battery[&:] ( or fill your tanks ) and have fun driving..
Old 01-25-2009, 02:17 PM
Metallover's Avatar
Default RE: How to: Lock the Jato into 2nd
Nice how-to and nice Jato! You really know how to build a fast jato. Throw out all that nitro... junk.
Old 01-25-2009, 03:20 PM
ORIGINAL: Metallover
Ty, now that it is locked into 2nd instead of the single speed conversion the gearing is ALOT higher.. I should be able to hit around 80ish ( Hoping for around 73ish) with the RCM speec calculator.. Yea I don't kno what to do with my nitro stuff..got a few NICE enginges with pipes.. and a few gallons of nitro oh well time to make a fire
Old 01-25-2009, 03:32 PM
Metallover's Avatar
I can't remember, were you running 3 or 4s lipo?
Old 01-25-2009, 03:54 PM
3s.. I could run 4s but with it being locked in 2nd I don't think I need 4s.. Im running high gear throughout along with 2.8 size tires.. 33/83
Old 01-25-2009, 08:31 PM
What kind of engines do you have lying around? By the way nice conversion.
Old 01-25-2009, 10:22 PM
Thanks man.. I got a 3.3 and a O.S. 18tm with a vantage pipe.. not much ran through it...
Old 01-25-2009, 11:42 PM
poor jato made into an electric []
Old 01-26-2009, 08:11 AM
Metallover's Avatar
ORIGINAL: siasinohio
Yeah I know, poor thing. It must hate being faster then nitro,,,
Old 01-26-2009, 02:12 PM
Yea poor thing its faster, quicker, lighter,stronger man what a sin.....Maybe when you can better yourself to realize that electric is the new wave of technology and is better in every aspect you will learn to respect electric... poor kid..[&o]
Old 01-26-2009, 05:15 PM
Metallover's Avatar
It's too bad that electric jato won't get any off days where it won't start anymore.[]
Old 01-26-2009, 05:21 PM
yea I kno I really love going outside and bringing everything and it won't start.. O well I guess I am going to have to live with plug in and beat nitros..
Old 08-19-2009, 02:28 PM
jpoprock's Avatar
I realize this thread is old... but I'm doing this very thing now... and I am LOST on something! It seems the most important picture isn't shown... and that is what the clutch should look like with the pins in it. He says he's going to drill one hole, but that clutch has like three extra holes in it! Just what is the "pin" supposed to do, or catch, or whatever?? His picture doesn't demonstrate what it's supposed to do exactly. Unless I'm not seeing it. Now my tranny is apart.. and I'm not sure what to do next.
Thanks guys!
J
Old 08-19-2009, 04:10 PM
Metallover's Avatar
I only see one extra hole...
Old 08-19-2009, 04:31 PM
jpoprock's Avatar
Maybe I'm not seeing it right?
2 Holes (i.e. stock)
2 holes stock, then three more? At least two more. No?
Old 08-19-2009, 04:46 PM
Metallover's Avatar
I don't have the parts myself, but if you do it should be pretty self explanitory. I'm assuming there's two parts and you want to lock them together with a pin. Just drill a couple holes and stick a couple pins in there.
Old 08-20-2009, 01:44 PM
Banned
Just a thought: My shift point was way off when I first got my jato. The screw was loosened about as far as it would go. Because of this the car would start off in second. I'm sure it was in 1st for maybe a split second when accelerating from a stop, but it was so short you couldn't tell it had shifted. It just ran like it was in 2nd all the time. Wouldn't this be an easier option than going into the tranny to lock it in 2nd?
Old 02-11-2017, 12:43 PM
I'd there a kit I can get becuse I don't have the tools
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
