Rustler Engine Help
My Rustler engine only runs when i directly enject fuel into the carb. I have good compression, newglow plug,and am getting fuel through the gas line. It dosnt look like fuel goes into the carb when pulling the throttle. Should i be able to see a drip/mist or something drop into the carb when pulling the throttle? If so how do i fix that, if not what are my other options? Any suggestions are helpful. My hobby store around here has been no help at all....
Thanks All, |
RE: Rustler Engine Help
If fuel's getting to the carb but not to the engine, I'd be checking the fuel passages in the carb. You might have an oil goober in there not letting any fuel thru. |
| All times are GMT -8. The time now is 07:45 PM. |
