RCU Forums
-   RC Nitro Stadium Trucks (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/)
-   -   need help with rc10gt diff problems (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/1450720-need-help-rc10gt-diff-problems.html)
steve10gt 01-20-2004 10:03 PM
i recently bought an rc10gt rtr plus and every time i run it the diff get dirt in it and i have to take it apart and clean it seems to be getting dirt right were the dogbone go's should i worry about this or not
ericheller 01-20-2004 10:07 PM
RE: need help with rc10gt diff problems
i wouldnt worry unless your getting it dirty on the inside of the diff.nitro cars usually get really dirty because of all the oil
david77449 01-21-2004 09:45 PM
Steve10gt and I run together and I have seen his problem. The dirt is actually getting into the diff inner gears and after several runs it feels very gritty when you hold it and turn the tires. It's actually so bad that the tires turn the same direction until it is taken apart and cleaned again. I helped him look and the case is sealed good so it must be getting in around the dogbones. I'm kind of curious myself as to why this is happening and if anyone else has been having this problem with the rc10gt. I've blown out diffs before but have never seen a diff that must be disassembled after every session and cleaned. This seems like a fairly serious enough problem.
David
flyingjibus 01-23-2004 01:30 PM
somethin sounds wrong to me. I never get dirt in my diff. even before I started using these:[link=http://rc10gthobby.com/transav.htm]tranny saver[/link]
ericheller 01-23-2004 07:10 PM
are you driving it through mud? im guessing when you say dirt is getting around the dogbones you mean that its getting in the tranny and up between the outdrives?
steve10gt 01-23-2004 11:58 PM
flyingjibus thanx for all the help im going to get some of those and they look like they will help my diff went out completly it got ate up bad
