RCU Forums
-   RC Nitro Stadium Trucks (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/)
-   -   help keeps stalling (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/1607682-help-keeps-stalling.html)
sean1234 03-09-2004 04:25 PM
help keeps stalling
Alright for some reason my car keeps stalling. I am on my 6 tank of gas and it stalls after like 40 seconds. it just did this like 3 times. the engine slows down a lot and then it stalls. Can someone tell me whats wrong?[:@]
ericheller 03-09-2004 04:57 PM
RE: help keeps stalling
ORIGINAL: sean1234
well are you letting it idle for 40 seconds? it sounds like your idle is just too low. 40 seconds though is a long time to let it idle, you can expect it to stall if the idle is set fairly low, or its slightly lean.
slodsm 03-09-2004 05:31 PM
Or even slightly rich if its loading up on fuel in the engine, it just cools the glow plug too much. What kind of engine?
sean1234 03-09-2004 06:50 PM
It is a stock rc10gt rtr, and i am not letting it idle, i will start it up and rev it up and start running it. Then it dies on me in less than 2 minutes. I tried turning up the idle speed but then i just have to turn it down when it warms up
ericheller 03-09-2004 07:08 PM
ORIGINAL: sean1234
when does it stall? when you apply the brakes or full throttle?
sean1234 03-09-2004 08:50 PM
when i apply the throttle.
C_Watkins 03-09-2004 08:53 PM
Sounds way lean to me... back out on the high speed needle and try it again.
Careful running it this way for too long without fixing it.
A bud just breezed through a brand new engine in less than two weeks like this.
ericheller 03-09-2004 08:54 PM
so it is cutting out? sounds like its too lean. i suggest turning the needles back to stock adjustments and starting over from there.
sean1234 03-09-2004 08:56 PM
alright but just the high speed needle right. i will tell you how it goes tommorow.
C_Watkins 03-09-2004 09:03 PM
To start with, yes... if you find that you've opened the high speed needle out more than 2
or 2 1/2 turns, and it's still doing it... I'd screw the low speed needle out about 1/8 turn,
and start over. It could also be some air leak, or that you've roasted the piston/sleeve,
but we'll keep our fingers crossed for you :) By friend's started doing the same thing,
after running it without tank pressure (broken cap) and getting it extremely lean.
Now, it runs fine for a few minutes, but quits when it's warmed up.
ericheller 03-09-2004 09:04 PM
ORIGINAL: sean1234
both hs and ls
