Spur gear.
I'm sure you have all seen you'r fare share of please help me this big gear is not moving or what not theard. Well this is a lil differnt. my spur gear is stripped, but only in 1 spot the rest is a lil bare but this 1 spot is done, every spur that i strip is like this, is this normal? or is the mesh not set right?--traxxas nitro sport-graphite spur or plastic or some other cheap material.
RE: Spur gear.
The only time I have seen that happen is when I got a rock caught between the spur gear and the frame the spur gear got all dented in that spot.
RE: Spur gear.
the spur is lasting about 50 runs mabey 20 hard runs, do i need to bust out the paper thingy? or is there no need to be busting out and paper?
RE: Spur gear.
my experience when the mess is too far away, it eats the spur gear up entirely. I think if its too close you will end up overworking your clutch bearing.
RE: Spur gear.
my motor seems to be snug so its not that.
RE: Spur gear.
don;t know what kind of car u have, wheather it is 2 wheel drive or 4 wheel...but try getting the aluminum rear bulk head for ur car.......my car was doing the same thing and it wasn;t my motor moving but my whole tranny shifting making the mesh to far apart...... ;)
| All times are GMT -8. The time now is 12:38 PM. |
