steering problems
Hi, Ive got a xxxnt, and whenever i accelerate it steers to the left and when i left it steers to the right.... what cn be causing this problem? I had the same problem on my tr4, and it was caused by a bent dog bone on that side, but the bones seem to be straight on my nt..i dont know what to do... tia
RE: steering problems
is the trim on your transmitter reversed?
I'm kind of taking a stab at this, I'm not sure if you ment that the steering is reversed or if your having trouble keeping it under control. But here goes both answers,
1- When you punch it the right rear tire is hooking up better then the left, loosen the slipper and tighten your diff properly. 2- If the steering is backwards, go into your transmitters program( hit both left buttons on JR ) and reverse the steering direction. 3- the third thing that might be your problem is when the truck starts to turn left, your feeding in the counter steer (right) too much, inducing the over steer. Try lowering your duel rates or travel end point. |
Bah! i totally forgot about the diff, tightened it up and it fixed it, thanx for all the help :)
| All times are GMT -8. The time now is 03:45 PM. |
