running in mud
i have an rc10gt. what can i do to protect it from mud damage, or should i not run it in mud at all
RE: running in mud
I have used condoms w/ my mini t, so anything rubber like a tamiya rubber bag or a large balloon. put silicon grease in the end and close it tight w/ a zip tie
RE: running in mud
what about the engine-will the filter keep out everything?
RE: running in mud
it should be ok as long as you dont run for an extended amount of time where the filter absorbs water then the water goes into the motor.
| All times are GMT -8. The time now is 04:38 PM. |
