starting after tuning
OK, if you have a new engine you go through the break-in process. After break-in you start to tune the engine. So what do you do the next day to start the engine? Do you return to base settings just to start? Or do you just richen it up a little to start, or should it be possible to start the engine right away at the tuned settings? I ask this because my engine starts a little bit harder now I have it tuned. Once it is started it runs flawlessly.
Thanks, Nick |
RE: starting after tuning
start it, let it warm up then tune it.
if its tuned good then it should start easier.
