NEED HELP!!!!
I recently got my truck set up right and running good. I ran about 16 tanks through my x-cellerator and then I broke my throttle servo. Two days later, I bought a Futaba S3003. I made some adjustments so it would fit and got it in there. The servo works perfectly but now my truck won't start. I flooded the engine three times trying. I leaned it out and it still doesn't help. Glow plug is brand new and glow igniter is fine. I'm thinking it's my engine. What do I need to check to see if it's my piston and sleeve? I can't go to my LHS because of my schedule. Any help or advice will be greatly appreciated.
RE: NEED HELP!!!!
What makes you think that you have a P/S problem ? Was your motor running poorly before the servo mishap? RED
RE: NEED HELP!!!!
My engine was running perfect before the servo mishap. I only think it could be my piston and sleeve because before i got the engine tuned properly my engine was running very lean and the guy at my LHS said that my piston and sleeve could be messed up. I got the engine tuned right and ran it rich and ran very good but now it's giving me problems.
RE: NEED HELP!!!!
Can you tell if the compression is good by turning the flywheel, does it make a thump sound when it comes off the top? RED
RE: NEED HELP!!!!
if its flooding, then that means your primeing it too much
RE: NEED HELP!!!!
Back off the rich about 1/8 turn and try that , RED
RE: NEED HELP!!!!
The compression seems to be fine. The flywheel doesn't make any thump sound. I will lean it some more just have to wait for it to stop raining. Thanks for the help.
RE: NEED HELP!!!!
ok when you start the engine ask some one to help you prime it a little. then get he other person to hold the throttle open all the way and when the engine starts let of the throttle that helps me a lot
| All times are GMT -8. The time now is 07:12 AM. |
