Large Problem
On my rc car i recently installed a cv-x engine. Everything seems to be set up perfectly lol yet when i give it gas my tires just do not move at all.The gears are lined up perfectly well as far as i can tell. Has anyone else had this problem and got a solution or any help they could lend me ill upload some images later thank you
sUrface |
RE: Large Problem
well... we have to diagnose the problem....
can you see your spur gear and clutch bell move? If the clutch bell doesnt move then its definatly possible that you didnt install the clutch properly, so none of the gears will move at all. Considering you just got a new engine, its my best bet. wheres the last place where you see movement from the transmission? |
RE: Large Problem
happen on my bros st before tighten the cvds they may be loose and slippin if i still doesnt move pup your truck when it is runnning give it gas and if they move thanyou stripped a gear
RE: Large Problem
ORIGINAL: Nitro Rustler Racer happen on my bros st before tighten the cvds they may be loose and slippin if i still doesnt move pup your truck when it is runnning give it gas and if they move thanyou stripped a gear Exactly what is there to "tighten" on cvds???? The only thing I can tighten would be the set screw, but even if it came out they wouldn't be "slippin".... |
RE: Large Problem
i had the same problem, but my rear wheels were loose
RE: Large Problem
surface.... tell us a little more about what happens and what you see.
RE: Large Problem
Very confused not sure what is wrong. i bough a new spur cause i thought maybe it was stripped which it was. I installed my new one. Went to start my engine up and it was going like full throttle so i messed with idle set screw got it back ot normal started it again went to push gas i saw the servo move but car didnt move alost the engine sounds like it was working but the tires just dont move :/ To much trouble with rc cars.
RE: Large Problem
ORIGINAL: sUrface Very confused not sure what is wrong. i bough a new spur cause i thought maybe it was stripped which it was. I installed my new one. Went to start my engine up and it was going like full throttle so i messed with idle set screw got it back ot normal started it again went to push gas i saw the servo move but car didnt move alost the engine sounds like it was working but the tires just dont move :/ To much trouble with rc cars. |
RE: Large Problem
does the spur gear turn?
| All times are GMT -8. The time now is 03:12 PM. |
