Engine trouble
My Nitro Evader starts right away but as soon as the engine gets warm and the first run is complete it takes forever to get restarted. Is there anything I can do to get the engine refired quicker?
RE: Evader Engine
Howz the battery in the glow igniter?
Try a new glow plug? Fuel fresh? Bill :eek: |
RE: Evader Engine
Brand new fuel and glow plug
any other ideas |
RE: Evader Engine
....let it cool down. MOST engines are fussy about re-starting warm.
RE: Engine trouble
I bet the piston and sleeve are worn down it's very common with DTX .18's. I ended up buying a WASP .18 ($100)it's a direct bolt on and LOTS more power. How much fuel have you ran through it probably 1 3/4 a gallon. When you run it does it over heat easily? It's very common with DTX .18's and it's usually the piston sleeve. Try to fix it some other way first, but send it back to the factory to get the sleeve replaced if you still have the warrenty. The sleeve is made of cheap copper so it doesn't last long. Once again don't go out and buy a knew motor. Try typing in " DTX .18 engine problems" in the search box, I had this problem a few months ago with my car and posted a thing here and they knew exactly the problem i'd read throught it it's got tons of troubleshooting.
RE: Engine trouble
mine does it alot. do this let it cool own so the head is warm, then prime it a little bit and give full throttle and start it as soon as the engine starts let of the throttle or just put the trim up all the way it works fine its just i got my bro helping me start it somtimes and he gives full throttle an it start right up
RE: Engine trouble
ORIGINAL: DJevader I bet the piston and sleeve are worn down it's very common with DTX .18's. I ended up buying a WASP .18 ($100)it's a direct bolt on and LOTS more power. How much fuel have you ran through it probably 1 3/4 a gallon. When you run it does it over heat easily? It's very common with DTX .18's and it's usually the piston sleeve. Try to fix it some other way first, but send it back to the factory to get the sleeve replaced if you still have the warrenty. The sleeve is made of cheap copper so it doesn't last long. Once again don't go out and buy a knew motor. Try typing in " DTX .18 engine problems" in the search box, I had this problem a few months ago with my car and posted a thing here and they knew exactly the problem i'd read throught it it's got tons of troubleshooting. The sleeve is made of brass not copper, A B C Aluminum piston , Brass sleeve Crome liner. |
RE: Engine trouble
my mach .15 is the same way...got to let it cool down
RE: Engine trouble
Buy a starter box, and start using it to start the engine. They work way, way better!! All my pullstart motors are a ***** to start once they are hot, I use the starter box, and bingo, they start immediately!
RE: Engine trouble
ive been contimplating that...just seems like it would work
RE: Engine trouble
i like pull starts cuz all you need is a glow starter and fuel an you can go anywhere with a starter boox you got to bring fuel ingitor and the heavy box, pull start easier:D
RE: Engine trouble
Hmm, my engine never struggles to start unless its overheated... gotta love my hpi.
RE: Engine trouble
hahhahaha lucky you [&o][&o][&o][&o][&o]
RE: Engine trouble
Thanks to the propper care of me on break in and after run [8D]
RE: Engine trouble
hahahhha,i id that too, just traxxxas engines on hot start up yukkkkky
RE: Engine trouble
i am soon to pick up a new engine though... this one will probably be a back up incase I blow an os lol.
RE: Engine trouble
lol, i dunt get it how can you blow the engine up?[&:]
RE: Engine trouble
My wasp starts easily in any condition and it's a pull start only $100 tooo much power (Is there such a thing?)
| All times are GMT -8. The time now is 07:31 AM. |
