trx 2.5 engine problem
i just got a nitro rustler and i think the piston is stuck. I am not sure what to do because me fly wheel will not move when i try to turn it.
RE: trx 2.5 engine problem
It sounds like your engine is flooded. Remove the glowplug unplug the fuel line and turn your engine over. Set everything back up and go from there.
Ultimate |
It also could be just so tight at tdc so try using a pair of pliers to move the flywheel, but first take out the glowplug so you lose some compression.
| All times are GMT -8. The time now is 04:46 AM. |
