RCU Forums
-   RC Nitro Stadium Trucks (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/)
-   -   wont move (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/2695415-wont-move.html)
traxxasrevolution3.3 02-24-2005 02:17 PM
wont move
I have a nitro evader and its been acting weird lately whenever you start you need to put it on full throttle when you try to start it or else it just dies when you give it gas after you start it. Also after you give it gas when you start it it idles fine but when you give it some gas it sounds alright like it a nasty sound and barely moves. Its not one of the gears I dont think because I checked them and they all look fine to me. Does anyone know whats wrong[&o]
gerwen 02-24-2005 03:03 PM
RE: wont move
Did you open up your transmission to look at the gears in there?
Dewgel 02-24-2005 05:17 PM
RE: wont move
I have this problem too, you're supposed to let the car idle for a bit, or hit it with a hairdrier...then it will be fine.
You're just damaging it by starting, then slamming the throttle up...don't even rev it to warm it up faster, just tap the throttle up every 2 seconds, so it doesn't cut out.
The taking off thing, check your clutch bell, or your spur gear cog thingy, that might not be connecting properly. (Engine may have come loose on chassis, or moved.)
