DIFF HELP
my diff comes lose every time i run my car i have to retighten my diff cna any one help[:o]
RE: DIFF HELP
I have the same exact problem...In my thrust balls i only have 2 out of 6 in there i have others to put in but didn't have time...Also when i hold my slipper with my left wheel held and spin the right i hear a grinding noise kind of is that because I'm missing 4 thrust balls?
RE: DIFF HELP
i have all the trush balls i greased everything last nightbut it keeps coming lose[:o] im going to tightenit more right now
RE: DIFF HELP
i went and put in the new balls and everything seems fine its 10:30 at night here so after church tomm. i will be running it...
RE: DIFF HELP
ya but i dont know why it comes lose i tighned uo im ging to look at it after dinet
RE: DIFF HELP
how do you know/tell it keeps comming loose?
RE: DIFF HELP
the truck dosnt move the the tranie spins and that iv rebuilt it 3 times i understand how the diff works the slipper gear i cranked it up to test the diff
1st the truck reves high but it hardily goes anywhere 2nd loss of top speed 3rd hold the slipper and disengaged the brake and try to tirn both tires make sure the slipper/sper gear dosnt MOVE turn both tires at the same time thats it slipping if its hard to move the tires but they move good if you cant move at all loosen 1/4 of a turn if they spin freely you will burn the diff in a hart beet this only goes for the evader i don't know what others do |
RE: DIFF HELP
ya i relooked at it nothing rong? as i can see i will run it next week its raining[:o] this was my week off 2:(
RE: DIFF HELP
The nylon nut that holds the diff together may be worn out. Replace it, threadlock it, or both.
| All times are GMT -8. The time now is 02:23 AM. |
