Stalling problems
This is Shortymet55. I am at Paul5150's house. I have a Rustler 2.5 with a stalling issue. When the car starts it is fine, but when I release my gas after some speed it will stall. What is the problem, is it fixable with proper tuning and how?
RE: Stalling problems
traxxas sais if that happens then you need to either change the glow plug or increase your idle speed. the idle speed worked for me. oh the other thing i found that can cause that is if you dont have your brake linkage set right, make sure its not to tight.
thank you very much!
| All times are GMT -8. The time now is 05:12 PM. |
