hello need duratrax help
I am new to all this stuff and i want to know if you can use a glo plug on a duratrax maximum st.
thanks jeff |
RE: hello need duratrax help
You have to use a glow plug in all nitro powered cars. In a max St you should use 20% nitro with a hot glo-plug like a O.S. #8 glo-plug.
dont use os plus unles its a os motor get the propper plug
ORIGINAL: nitro666 dont use os plus unles its a os motor get the propper plug |
ORIGINAL: yoster ORIGINAL: nitro666 dont use os plus unles its a os motor get the propper plug |
O.S. plugs may be more spendy but they last alot longer. I use cheapy plugs for break-in cause i change em out but once i get the truck dialed i switch to a O.S. plug!
thanks for the help
| All times are GMT -8. The time now is 11:11 PM. |
