RCU Forums
-   RC Nitro Stadium Trucks (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/)
-   -   how much (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/2919674-how-much.html)
speed demon 00009 04-27-2005 01:20 PM
how much
Hey guys,
I am wondering how much you think my GT is worth because i might get rid of it [:o]
http://img252.echo.cx/img252/9651/dscf0001hghg4ue.jpg
http://img98.echo.cx/img98/3388/dscf013412xz.jpg
http://img137.echo.cx/img137/6074/dscf012718xz.jpg
mittimj 04-27-2005 01:33 PM
RE: how much
need more info to tell, any wheres from 100 to 250
speed demon 00009 04-27-2005 01:43 PM
RE: how much
ok
4 aluminum a-arms
1- rear bulk head
1- rear aluminum shocktower
1- front aluminum shochtower
1- alloy front c-hub set
1- alloy rear hub set
1- alloy steering arm set
12- RPM heavy duty rod ends
1- RPM reciever box
1- robison racing combo 65t/15t bell
1- alloy rear extended tranny brace
2- rear tmaxx springs
1- futaba steering servo and reciever
1- JR racing throttle servo
1- air filter
1- venom hump back battery pack
1- venom fail safe
4- 4 sets of tires
1- Megatech Q-series .16 engine 1.6 horse power
1- bump box
1- tool box with every tool that will work for the rc10gt.
Tricksligger 04-27-2005 02:39 PM
RE: how much
1 Attachment(s)
I just sold a all blue aluminum Duratrax Max ST Pro w/ a Os .18cvr. RTR with Futaba radio and got $200+25 shipping.
Here is the description I gave:
With the Os .18 and the 2 speed adjustable tranny this is the fastest Stadium truck youll ever drive. It pulls wheelies on command and screams at high speeds. The Os 18 only has about 12 tanks through it and has been taken care of. The truck has almost every hop up available including: Aluminum A-arms, aluminum belcranks, aluminum hubs and hub carriers, aluminum servo horn, aluminum threaded shocks, aluminum chassis and radioplate, aluminum centergear in tranny. Hopups also include a micro-venom temp gauge, steel gear differential set, custom fitted fiberglass vented brake disc, Os .18, and a tuned pipe with exhaust deflector. Servos have been plastic dipped.The radio is a Futaba radio with throttle trim, steering trim, servo reversing, steering d/r, Throttle epa, steering epa. It is the futaba MJ T2phka.
In reality the truck I sold wasnt as nice as yours, but it looked better. On Eba* its all about looks to the newbs.
You should be able to get like $270-$300 tops
savageman90 04-27-2005 03:29 PM
RE: how much
put it on e bay and you should get about 300 for it... and maybe more
killer89 04-27-2005 05:25 PM
RE: how much
100
speed demon 00009 04-27-2005 05:51 PM
RE: how much
ORIGINAL: killer89
100
are you serious??
Skullbasher 04-27-2005 06:05 PM
RE: how much
Knowing Erik, he probably is...
