RCU Forums
-   RC Nitro Stadium Trucks (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/)
-   -   XTM EXCELERATOR HELP (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/3050693-xtm-excelerator-help.html)
CRASH MAN 06-07-2005 11:01 AM
I CAN'T GET MY TRUCK TO HAVE ANY GRAB ON ANY SURFACE OTHER THAN CONCRETE. IT SPINS OUT ALL THE TIME AS SOON AS YOU GIVE A LITTLE THROTTLE. I HAVE BACKED OFF THE SLIPPER CLUTCH QUITE A BIT, CHANGED TO MORE AGGRESIVE TIRES, LOOSENED THE DIFF A BIT, AND I STILL JUST SPIN OUT EVEN WITH THE MOST SUTTLE THROTTLE. ANY ONE OUT THERE HAVE ANY SUGGESTIONS OR HAVE DEALT WITH THIS IN THE PAST?
jjmag26 06-07-2005 12:19 PM
RE: XTM EXCELERATOR HELP
You can soften the rear springs a little allowing it to squat a little more giving it more traction. If you are running the stock engine it's a beast and has way more power than needed in the small truck so throttle control is key. Just lower the rear abit by unscrewing the preload on the shocks a little and that should help alot.
sledmanass 06-07-2005 06:12 PM
It should grab on grass
jdh 06-07-2005 08:35 PM
I had the same problem when trying to run the X-C at my local track, hard packed clay very dusty and slippery. Seem to have it dialed in pretty good now with the following settings:
Front:
20 weight shock oil (10 is standard)
1 degree toe out
Stiffer front springs (to get a bit of weight transfer to the back)
Proline Edge tyres
Rear:
20 weight shock oil
4 degree toe in rear arm mounts
stock springs
Proline Holeshot tyres
Shock moved to most upright position on shock tower
I got all of this info from the XTM X-C forums at:
http://globalservices.globalhobby.co...wforum.php?f=9
