~Preperation~
[sm=spinnyeyes.gif]~How should i send my engine in to duratrax?...shoujld i take off the clutch so it only has the flywheel and the shaft attached how should i do it~[sm=spinnyeyes.gif]
RE: ~Preperation~
take your...
clutch bell, clutch assembly, Flywheel, glow plug(If good:D), and Recoil off then you should be good to go[8D] -Ryan |
RE: ~Preperation~
so u decide to send it back
glad we told u to send it back well humm glow plug CB clutch fly wheel maby the carb? i dont know if then just send u a brand new one of repare your old one i will have to ask my friend what happened with his i will up date soon :D |
RE: ~Preperation~
They should give me a new one considering mine has NO compression anymore and stalls and wont start back up once it is warmed up.!
RE: ~Preperation~
no they will probably just resleeve it and a new piston. whatever whay you send it is how you will get it back.
RE: ~Preperation~
even if i re-sleeve it it will still be the same as getting a new engine right?>
how do i get the clutch bell off? |
RE: ~Preperation~
nvm..im retarded
RE: ~Preperation~
lol:D just one of those days hua:eek:
| All times are GMT -8. The time now is 03:54 AM. |
