OS CV-RX(s) .18
Will the diff. gears, etc. in the RC10 GT handle the power of an OS.18 CV-RX?
Anybody have any personal experiences with one? |
RE: OS CV-RX(s) .18
They should be enough to handle it. If you dont feel safe buy some new diff components.
RE: OS CV-RX(s) .18
Suggestion: I have Nova mugen engine in my gt this engines are so powerful, at first time I broken the diff, then I learn that loose the slipper clutch a little you can safe the diff. try this lock the tires then force move the spur if you see that the diff slip then slipper clutch is too tight then need to loose it until slipper slip first than diff, This way all excess of force will go by the slipper clutch and not by diff and diff will be more durable with power engines. Only you need is give the diff regular maintance to keep it good for long time.
