RCU Forums
-   RC Nitro Stadium Trucks (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/)
-   -   WHY? (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/3399114-why.html)
RC04 09-27-2005 01:21 PM
WHY?
My buddy converted his gt to a starter box went out and bought a cheapy starter box like 70 bucks. THe starter box ahs been used 20 times and never broke yet! good news :). Im thinking of converting my pull start rc10 gt to a starter box. Pros and cons people pros and cons lets hear the suggestions.
avg_joe 09-28-2005 12:03 AM
RE: WHY?
You don't need to 'convert' anything unless you need to change the flywheel. You can use a starter box on an engine that has a pull start installed.(just to clarify;))
WAY more pros than cons.
The only drawback that I see, is that you need a power supply, and you need to bring your truck over to the power supply to start.
It is so nice to start a truck on a box...you can do it with the body on easily...easy to prime by plugging stinger while starting...you can spin an engine longer for those stubborn warm restarts...
ThunderbirdJunkie 09-28-2005 01:41 AM
RE: WHY?
RC04, my starter box is cheaper ($35 Duratrax thing), and THAT was NEW!
ever since goin to a starter box, i wont go back, EVER. cons=lugging around a battery, but big deal:P
dannthenitroman 09-28-2005 04:43 AM
RE: WHY?
same here, once you go box, youll never go back!
Dann
The_Collector 09-28-2005 08:42 AM
RE: WHY?
To me, pull-start is more convenient.
Midget 09-28-2005 08:53 AM
RE: WHY?
ORIGINAL: The_Collector
lol u must whear gloves all day (i get bliters like hell from pull starts)
Midget 09-28-2005 08:55 AM
RE: WHY?
what i did is a waitend till me pull start broke then i took all the stuff out of it and i used it has a back plate:D
ThunderbirdJunkie 09-28-2005 10:05 AM
RE: WHY?
collector...depends on your definition of convenient.
WAY easier starting with a starter box. pop the truck on there, pop on your glow plug ignitor, and push down:D I've had a few cold-blooded engines that wouldn't start for nothin when hot....a few seconds of crankin wwith the starter box, BAM, she be done:D
RC04 09-28-2005 03:43 PM
RE: WHY?
Ok so first tell me step by step once i remove the pull start from the car than what do i need to take off and put on for the starter box.
I have a power supply for my duratrax ice charger its a 12amp and it plugs into the wall so how do i use the starter box at a racing track with no plug? Thanks guys... sounds alot more comvieniant
What if I get the starter box that uses that batteries from my rc car? cause this one uses batteries i think:
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA%3AIT&rd=1
RC04 09-28-2005 07:25 PM
RE: WHY?
Bump...
The_Collector 09-28-2005 09:13 PM
RE: WHY?
Most of the Nitro stuff I own will usually start with 5 pulls or less.;) Maybe I just have the magic touch...
badz 09-28-2005 11:04 PM
RE: WHY?
RC Math...
5 pulls is > 1 bump
repairing a pull starter > carry around starter box battery
dannthenitroman 09-28-2005 11:10 PM
RE: WHY?
badz, well said, coodna said it better :)
Dann
Shmeal 09-28-2005 11:43 PM
RE: WHY?
i have a truly lazy way.
Pick up car by pullstarter
give it a little shake
car drops, and car starts
easy as cheese
avg_joe 09-29-2005 12:06 AM
RE: WHY?
Most starter boxes have a plug that connects to a set of jumpers that you can hook up to any 12 volt source(car battery, security system battery...), or you can usually hook up 2 standard stick packs.
I don't think you have to remove your pullstart, unless you are trying to save weight.
ThunderbirdJunkie 09-29-2005 01:23 AM
RE: WHY?
avg...i use the old battery outta my motorcycle for that;)
yoster 09-29-2005 01:49 AM
RE: WHY?
I have both a pullstart and a starter box. I would much rather "lug" my starter box around. It is actually no extra burden. The starter box is in my larger box of rc stuff I always bring with me when I go. Just throw it all in the trunk of my car and take off. When I get to my destination, I take out my fold-out char, take out my rc box.. and set myself up. Not having the box with me wouldn't save me a single bit of time.. so might as well bring it. I also like it because I don't have to fish around for the pull start when I have the body on. Its just quicker to have the starter box I think. Plus, I ALWAYS forget to charge my glow starter, which forces me to use the one that connects to my starter box.
RC04 09-29-2005 10:58 PM
RE: WHY?
Thanks guys
The_Collector 10-02-2005 12:06 AM
RE: WHY?
Guess I'm the oddball here.
jkulhanek 10-02-2005 12:34 AM
RE: WHY?
Collector, i'm with you!
jkrustchinsky 10-02-2005 12:45 AM
RE: WHY?
i use starter box and will never go back, collector, what if your engine decides to be stubborn that day??? i remeber my street forec pull start, my pointer finger nad middle finger were blistered to hell after a day of running
jkulhanek 10-02-2005 12:56 AM
RE: WHY?
Blisters?? Eat a bag of concrete and harden the F$#% up :)
I do not have any problems with my pullstart, it starts the engine easily even when hot.
I just can't justify spending the extra dosh on something that i don't need.
If you guys are too lazy to tug a little handle half-a-dozen times...that says a lot :eek:...
Midget 10-02-2005 06:01 AM
RE: WHY?
ORIGINAL: badz
RC Math...
5 pulls is > 1 bump
well i gess its hes choise if he thinks that a pull start is better then let it be his way
who realy cears
but i agrea with u starter box is heps better
