SH28 engine
hi
im getting a sh28 engine for my evader will it kill my tranny (i gess it will lol) but will i have to get a mettle gears and stuff im not sure so can you guys plz give my some links or some think so i know what to buy so i want kill my car thanks heps |
RE: SH28 engine
Holy crap, your gonna put a big block in a st. That seems pointless to me. Your never going to be able to keep the truck from flipping over. Even if you buy a os 18 cv-rx, you would still have a hard time keeping the front end down. I would like to see a vid tho with this sh28 lol. I would try to get all metal gears. Damn traxxas doesnt make metal spurs yet and I jsut completely stripped one yesterday.
RE: SH28 engine
ShVdCaT did it to a duratrax maximum ST and posted a vid. Check it out. It is all in sand and it is completely wicked!
RE: SH28 engine
Dude! Most savages can't handle that![X(]
RE: SH28 engine
ShVdCaT did it to a duratrax maximum ST and posted a vid. Check it out. It is all in sand and it is completely wicked! Where's the vid? |
RE: SH28 engine
so yes i will need metle gears
and wheres the vid? |
RE: SH28 engine
That engine won't be a direct drop in. You'll probably have to fabricate a motor mount, or at the very least drill some extra holes in your chassis. I don't know if your clutch and bell will fit on it, or if it will line up with the spur if it does.
Honestly that's probably way too much engine for that truck. You can get all the power you'll ever need, and then some with an .18 CV-R. and it should drop right in. That sh.28 in a stadium truck will likely not be any faster or quicker than an .18CV-R The extra power it produces will only make it harder to control, and easier to lose rear traction, so you won't be able to acclerate any faster. The CV-R has a higher max RPM so it will likely be faster than the SH for a given gearing. Now, all that being said. If you're doing it for the challenge of shoe-horning a big mill into a little truck, and to learn and experiment, then go for it and good luck. Sounds like a fun project, and you'll have some bragging rights, because it's doubtful that there's many ST's around with a .28. |
RE: SH28 engine
lol thanks all for your coments and stuff
im buying the engine today of off a freind for $120 and giving him my enigne(which is dead but i think he want the crank case more than anythink) this will most likly be a long term project becuase im saving up for a hyper 7, so when eva i get some spear money or some think ill get the gears and stuff that i need for it. and when im finshed ill post some pics and a vid[>:][>:] |
RE: SH28 engine
RE: SH28 engine
1 Attachment(s)
The sh .28 will tear apart the evader. Not just the tranny the whole car. Here are some pics for you. The first is a sportwerks .26 next to a os .15, and the second is it next to an evader. Just to let you know, the .26 is actually smaller than my rd logics .28 by a good bit.
| All times are GMT -8. The time now is 04:17 AM. |
