Air Filter??
what air filter should i get to kepp out sand on my gt.
RE: Air Filter??
a paper k&n looking like filter is good because it repels sand thats what i have on mine with a spung prefilter, or a motor saver airfilters are good.
RE: Air Filter??
no K&N filter is good...they are the worst air filter you can buy for a rc motor!!!!!!!!!!!!!! They were designed to be a breather filter for automotive applications
Use a foam filer with a foam pre-filter...make sure you use good air filter oil Motor saver is you best bet, that's what I run on my trucks. I also use the dust/mud cap when track conditions are bad |
RE: Air Filter??
it depends if you have a slide carb or a rotary carb? the rotary carb is smaller
here is the AE one and i was told it works great- http://www2.towerhobbies.com/cgi-bin...?&I=LX3408&P=7 so a search for "air filter" on tower |
RE: Air Filter??
Motor saver works good for me.
RE: Air Filter??
i would go with www.rbinnovations.com air filters there really good and they look good
RE: Air Filter??
I use a GPM two stage. It has a paper iner with foam outer, Good http://www.hobbyetc.com/cgi-bin/cata...m&lim=0filters
| All times are GMT -8. The time now is 10:33 PM. |
