engine question
i know these has probably been asked before but i know this engine is a small block .23 will it work in a jato just ouy of curiosity because if so im doing it.
http://www.hobbypeople.net/gallery/838200.asp |
RE: engine question
yes i think it ill, but first consider how much space the stuck engine has in ALL directions including between the engine mounts and think will a moter that size fit, if not think what can be dremmeled but other than that is is a direct bolt it.
Dann |
| All times are GMT -8. The time now is 02:12 AM. |
