rc10gt question/problem?
ive just got my rc10gt back together to run and when running it for a few seconds i noticed when i gas it it goes and everything but its almost like theres friction somewhere and when i turn the wheels the clutch bell doesnt spin freely.. im pretty sure its the bearing in the clutch bell but before i go waste time going to the hobby shop anyone else have any ideas? Btw the brake isnt rubbing.. thanks ahead of time
RE: rc10gt question/problem?
either the bearing is bad or maybe it is rubbung on the screw on the end of the clutchbell. Lossen that a 1/2 a turn and see it that is it. if not pull the motor out and check the bearing first by taking of the clutch shoes then put the bell back on and spin it. if it spins freely maybe the clutch is rubbing on the clutchnell. trim the trailng edge of the shoes about 1/16 of a inch to make the overall diameter smaller. it sounds like that could be the problem or maybe the clutch shoes are not pushed on the tabs all the way. this will also make it rub. good luck. if worst come to worse take the motor in the to hobby shop and they should be able to figure it out.
nvm fixed it a weird linkage prob but its good sry for the lame post
| All times are GMT -8. The time now is 04:56 PM. |
