RCU Forums
-   RC Nitro Stadium Trucks (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/)
-   -   XTM XC Problem (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/3997674-xtm-xc-problem.html)
TRCX 03-06-2006 07:11 AM
XTM XC Problem
hi all [8D]:)[sm=sunsmiley.gif]
i got a xtm x-cellerator a few weeks ago,:D and ever since i got it the one way bearing or what ever they use in the pull-start has been giving me problems.[:-][:o] At first it just didnt grip the crankshaft,[:@] it did this at random, but now it has just locked on to the shaft and wont release![:-]:(:([sm=drowning.gif]
please help :eek::eek:
[sm=idea.gif]thanx in advance!:D[sm=wink.gif]
annie_himself 03-06-2006 07:24 AM
RE: XTM XC Problem
Since it won't release your engine could be flooded or even hydrolocked. Lets hope not, but try to get the gas out then start it.
ryan_t888 03-06-2006 10:25 AM
RE: XTM XC Problem
ORIGINAL: annie_himself
Good Point
If this is the problem, take out the glow plug and give the engine a few tugs. Fuel will spray out, then reinstall the plug and try again.
Also, I would carefully take off the starter. As you are taking it off, try not to disturb any of the internal parts on the starter as re-coiling it is a pain. Usually when I do this the oneway bearing is remaining on the starter shaft. From here you can try to turn the bearing in order to see if it is functioning properly.
Ryan
pete8541 03-07-2006 08:08 PM
RE: XTM XC Problem
I have had a bunch of xcs They are a good truck but the weak link is the pull start. Mine have run much better after I tore that pice of crap off.
maxxhavoc 03-08-2006 01:01 AM
RE: XTM XC Problem
mine starts up in 4 pulls. its been a great truck ever since i got it tuned. but yeah sounds flooded.
annie_himself 03-08-2006 03:59 PM
RE: XTM XC Problem
One pull for me and a screw is still missing. The HPI Roto-Start fits perfect.
Kemo 03-08-2006 04:56 PM
RE: XTM XC Problem
ORIGINAL: TRCX
Rotostart wont help if he has one way bearing problems. Clean it, and lube it. see what that does.
TRCX 03-10-2006 02:06 PM
RE: XTM XC Problem
hi all
the engine is difinitley not hydrolocked or flooded, it is definitley the one way bearing, i cant even got it off the crankshaft![X(]
Help please!:eek:
Kemo 03-10-2006 02:37 PM
RE: XTM XC Problem
Hmm, find a flat head screwdriver and see if you can pry or pull it off with that. If that doesnt work, find a hammer and GENTLY tap it on every side of the nut. It should come loose eventually!
