engine help
i have the trx 2.5 and its having problems. it acts like as if it isnt getting any fuel, but it is. i end up re priming it in order to run, but when i do it runs for a few seconds and dies. i checked for leaks in my fuel line and tank, there is none. i checked to make sure all was tight on my engine, it was. it still is habing issues.
what shoud i do? |
RE: engine help
from what i have been seeing is if you have a priming bulb on the tank most of the people here either change the tank or take out the priming bulb and seal the area that it was in very well and test for leaks
RE: engine help
i have a primless tank. i blow on the pressure line to get fuel into the engine
RE: engine help
Do you still have the ez-start on it? Do you cover up the exhaust and crank it over?
RE: engine help
sounds like its very lean, or stuffed glow plug .
Dann |
RE: engine help
My 2.5R was doing the same damn thing, brand new at that even. Anyhow, it seems after bashing around, the tranny case hit the rear of the carb, at the time I didnt know. check that cps carb for a crack or 2. Then ten bucks down to hobby shop, get new fuel line and a filter, ofcouse if the carb has a crack, get a new one, OS make good replacment ones.
Sounds like a air leak of some kind. |
RE: engine help
i here a small hissing noise coming from it when i put my ear up to it, all my bolts are tight. i dont know what the hell is wrong. its realy starting to tick me off!!! my carb is fine, its clean and crackless all is how its supost to be
RE: engine help
Make certain the HSN is at factory settings.
How is the LSN? If you believe it has fuel when you first try and start it, perhaps the LSN is too lean and the engine is starved after a few seconds. How about if you start the engine with 1/2 throttle? If you maintain some throttle will it continue to run or stall? Ryan |
RE: engine help
i am just about ready to give up on nitro. it has been nothing but trouble since i got one. i had it for about 2 months and i was only able to get about 1/4 gallons through it because somthing was always not working right or broken. i may trade it in for a at rc18 mt.
RE: engine help
nitro is not for all people some people prefer to stick with electric plug n play. what other problems have you had did you seal you carb
RE: engine help
i would take the whoel engien apart and clean off all of the resedue. thats what i did for the trx i took a dremel to it with a little wire brush. might sound crazy but that resedue in ther can fu*k up an engien prety bad. and the dremel with a wire brush dident hurt or scratch anything. jsut consider cleaning all of the internal parts or the engine.
RE: engine help
RE: engine help
Oil residue will not hurt a thing and it is there for a reason. I would not want to start an engine dry without some form of oil coating.
Ryan |
RE: engine help
it is not oil resedue it is from the fuel it is red and holds up the piston and coudl even seize it up. it happend to my t-maxx
RE: engine help
I have never heard/seen anything other than oil being left in the engine(brown). I would quickly change your fuel brand as there should never be anything red in the engine holding it up.
Ryan |
RE: engine help
Really richen up high speed needle, I live in northern wi and because of cold temps 4 turns out was still really lean, had to go with 5 full turns out to keep it running well when temps were in the 20's. When my engines die out of fuel starvation and I'm still certain it's getting fuel guess what? I'm always wrong:D if it was getting fuel it would not die when the prime was run out.
RE: engine help
ORIGINAL: Matt G Really richen up high speed needle, I live in northern wi and because of cold temps 4 turns out was still really lean, had to go with 5 full turns out to keep it running well when temps were in the 20's. When my engines die out of fuel starvation and I'm still certain it's getting fuel guess what? I'm always wrong:D if it was getting fuel it would not die when the prime was run out. isint factory setting's 4 turns out on the hi-speed? im just wonderin if if the weather in wi affects it? i live in michigan. and i am about the same |
| All times are GMT -8. The time now is 03:28 PM. |
