RCU Forums
-   RC Nitro Stadium Trucks (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/)
-   -   OMFG Flywheel Doesnt Turn Over the Engine! (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/4107289-omfg-flywheel-doesnt-turn-over-engine.html)
happyhobo69 03-31-2006 01:13 PM
Ok just wat I said. I have the Mach .15 RE on my XXX_NT. Somthings wrong wit it. I would call them but.... Our hours are from......Ok so the engine starts with the roto start BUT It wont stay running and it revs high but doesnt move the car. I noticed that I can move the freewheel all ways and doesnt turn over the eingine....WOW PROBLEM. What do you think is wrong. I called the local hobby shop and he said "I dunno what to tell you" well dam. I bought a TRX .15 4 40 bucks but the mounts dont work cause the pilot shaft is TO ****ING SHORT AAAHHHHHHHHh. BTW the pilot shaft on the Mach will turn over the engine just not the flywheel. Looked in the case and all looks fine. Any help would be greatly appreciated.
happyhobo69 03-31-2006 01:20 PM
RE: OMFG Flywheel Doesnt Turn Over the Engine!
oh yea It is NOT the diff!!
RallyRed 98 03-31-2006 02:21 PM
go through and make sure everything up to the spur gear is tightened properly... maybe worn clutch shoes.
happyhobo69 03-31-2006 02:30 PM
Took all of that off and its not the clutch or the spur...Have the egine off the car and I have everything off the pilot shaft except the flywheel ause i dont have the piston locking thing. Soo its definantly that.
jato/xxx-nt 03-31-2006 03:35 PM
i think the mach.15 engines arent that good for that long of a time. because im prety sure mine jsut took a crap. anyone knwo where i can get a good engien for the NT for not that much ???
happyhobo69 03-31-2006 03:48 PM
Not on this post thats where!
yoster 03-31-2006 04:01 PM
ORIGINAL: happyhobo69
LOL. Way to nip that in the bud!
happyhobo69 03-31-2006 04:17 PM
Yea i hate when that happens. The title says Rc car engine problems or somthing and at the end people are talking about planes.
125cchyperman 03-31-2006 04:39 PM
The only thing that i can think of is do you have the Flywheel collet on the crank. If not the flywheel will not be able to turn over the engine at all. And that would leave you with eratic engine behavior. If the engine even would start and stay running. Another thing is do you have the clutch nut on tight. This has happened to be a couple of times that the nut will loosen it's self from the vibration of the motor and such. When the clutch nut is not tight it will not apply enough pressure on the flywheel which will in return not have enough pressure to turn over the engine. If the flywheel is not turning over it will leave you with eratic engine behavior. These are the only things that i could think of that might leave you with those types of engine problems. Ihope this helps you with the problem
