attn d_dubdb3
hey dave it arrived thanks again for the bargin!!! just one thing could you let me know which verison it is for the parts manual, is it the 2.5 or pro .15 laters
laserman |
RE: attn d_dubdb3
If it has stock cooling head, you can tell by the profile of the head...
The pro.15 has 4 bolts holding it on, and has a 'normal' profile...It is straight up and down, and the fins are evenly spaced. The 2.5 has 5 bolts in the cooling head, and its profile is bulged in the middle, and the fins aren't all evenly spaced. (also has little plastic do-hickey on the top of cooling head, so you don't scratch it up when you flip it over...or at least it did until somebody flipped it over...) |
RE: attn d_dubdb3
this is a roller no motor
RE: attn d_dubdb3
Oh, dang....Here I thought I was being smart.[:@]
Is there a difference in the trucks? I thought it was just a different engine on the same truck. |
RE: attn d_dubdb3
i found out which one it is as there are slight differences between the 2.5 and .15 and since i am installinga OS .15 cvrx in it i think it will run very well. just have to finish the mod for the motor mounts as the OS is bigger in some areas but once it ready (in few days ) i will get it out and do some driving with it
| All times are GMT -8. The time now is 07:18 PM. |
