RCU Forums
-   RC Nitro Stadium Trucks (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/)
-   -   EVADER HELP! (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/4214219-evader-help.html)
Evader ---> MGT 04-27-2006 06:38 PM
EVADER HELP!
Read the bottom please.
RC+3 04-27-2006 08:14 PM
RE: Evader Steering problem
That would be my first guess.To be sure take servo out then hook it back up and try steering.As a after market,Thats your pic its all about the benjamins.
125cchyperman 04-27-2006 08:14 PM
yep sounds like the gears inside just stripped. Tyr getting a high torque, high speed owith metal geras. I would go withthe jr Z590M it has a all of the above so it should be good enough. well good luck
Evader ---> MGT 04-27-2006 09:38 PM
the jr looks good, but is the Hitec HS-645MG High-Torque 2BB MG Servo better? It's metal geared and hi-torque. Also it's less expensive. Would it fit? There is a J and a U or something right?
Evader ---> MGT 04-27-2006 09:41 PM
Also, the servo saver, wherever that is, and the bell crank assembly, will they fit?
Evader ---> MGT 04-30-2006 01:19 PM
Ok, i got a new futaba hi-torque servo but whenever I turn the wheels turn, but when I release the steering wheel, the wheels don't go back straight. I got the steering horn set and attached the one that was the tightest to the servo but it seems like it strips whenever I turn. Please help.
