RC-10GT pullstart to non pullstart motor mount
I got the flywheel and I noticed how much smaller around it is. How does the starter wheel even touch it? Is the motor mount lower on the non pull start?
RE: RC-10GT pullstart to non pullstart motor mount
Correct! You will need a non p/s motor mount.
That is the difference between the pull and none pull starter mounts. With a pull starter normally the bottom of the pull starter is lower then the engine case so you have to have higher mounts. None pull starter you have to have the motor lower so you can get something to start it on the flywheel.
Thanks guys. It will be here on tuesday.
Way to go. Starter boxes are the way to go. :D
Yeah man after yanking on that pullstart AE.15 all day after it warmed it up was a @#$% So I had to upgrade to a OS .12cvr and a box
| All times are GMT -8. The time now is 11:51 AM. |
