Vantage pipe
If a put a vantage .12-.15 pipe on a stock traxxas jato will it increase its speed. And if so by how much?
RE: Vantage pipe
RE: Vantage pipe
You will increase a lot of speed. I do not know how much though. I have one on my jato and i pop wheelies like no tomorrow. It's super fast. I ended up eating the stock tires within 7 tanks.
RE: Vantage pipe
for that amount of money it better increase speed. ;\
RE: Vantage pipe
Suggestion before you buy one do some research on pipes and read this.
http://www.*********.org/fantom_tuned_pipes.htm In my opinion there are a lot of much better pipes. |
RE: Vantage pipe
Dual chanber resonator are preaty good i have one on my Jato. http://www.rcplanet.com/images_produ...ual_b71675.jpg
RE: Vantage pipe
ok thanks:D
RE: Vantage pipe
That is the Fantom site talking about their own pipes. Does what they say hold true for pipes in general?
I know the size and shape of the convergent and divergent cones also make a difference. I used to have a link to an article that explained how and why a tuned pipe works, but it's a dead link now.:( It was a good article with diagrams and everything. Length of the whole system is also a factor to consider. I have read about how you can trim off the end of the header(the pipe end, not the manifold end;)) to shorten the system to time the pulses. As a general rule...as I understand it...shorter pipes with longer divergent cone/short barrel/short convergent cone are suited to high RPM. ...long pipes/long barrel/short steep cones are suited to torque and lower end power. Once you take into consideration all of the variables and do some figuring and calculations...get the one that sounds cool.:D |
RE: Vantage pipe
tHANKS
RE: Vantage pipe
1 Attachment(s)
Not sure you can read this but I am trying. As far as the material a pipe is made of yes the Fantom site is correct for all pipes! If you want more insight on it go to any site that talks about pipes for motocross and you will be enlightened. Heat is very important on how a pipe works.
RE: Vantage pipe
ORIGINAL: ICrashThings for that amount of money it better increase speed. ;\ |
RE: Vantage pipe
Suggestion before you buy one do some research on pipes and read this. http://www.*********.org/fantom_tuned_pipes.htm In my opinion there are a lot of much better pipes. |
| All times are GMT -8. The time now is 09:22 PM. |
