engine lock
My mt2 is having trouble starting, as soon as i put the rot start in my engine and press the button it locks, i charged the battery in the roto, still locks, im guessing this is v bad?
thanks rcmate |
RE: engine lock
You are probly experiencing hydro lock. Take the glow plug out and try it then. If it is hydro lock then it will push all the fuel out the glow plug hole so watch your eyes as the fuel will spray up at you. If it is not then you may have gotten a pebble or something in it and it is stuck between the piston and on of the ports. Or the wrist pin c lip may hace backed out and the wrist pin may have slide out and may be catching one of the ports. Try the glow plug things then if thats not it you may have to tear the engine down to find the problem.
RE: engine lock
yeah hey that was it, thanks 125
rcmate |
| All times are GMT -8. The time now is 05:47 PM. |
