RCU Forums
-   RC Nitro Stadium Trucks (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/)
-   -   RC10GT (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/5113755-rc10gt.html)
the shiz 12-13-2006 10:48 PM
RC10GT
I have a RC10GT with a box starter setup can I convert it to a pull start?
pics or websites would help
46u 12-13-2006 10:57 PM
RE: RC10GT
ORIGINAL: the shiz
Yes it would cost a good bit and the best way would be to get another engine as the parts would cost you just about as much.
jdeadman 12-14-2006 11:30 AM
RE: RC10GT
Not really I have changed one just by adding a spacer to the engine mount (aluminum or composite is best) of about 1/4" so the pull start will clear the frame. and just bolt on the approporate starter/starting shaft for that engine. most have tham available. Just keep in mind depending on the motot you have to seal up the back plate when you install the starter shaft backplate. I use RTV non sillicone.
Cheers
the shiz 12-14-2006 07:04 PM
RE: RC10GT
my friend also is giving the stinger exaust to me which routes it to the back could i put a pull start in then?
