mt2 diff
well i got new diffs for my mt2 i know how to change it all but i dont no where the shims go or how to shim it right they came with 3 shims any help would be great.
RE: mt2 diff
anyone:D:D
RE: mt2 diff
http://kedar.itgo.com/tipz.html
scroll down on that page and you will find a section called "diff modz" that should have everything you need. |
RE: mt2 diff
You have to shim the pinion like they are showing on that site but you all so have to shim the ring gear over towards the pinion. You want it about as tight as you can get it with out any bind or rightness. If I keep time I will try to get some drawings up.
RE: mt2 diff
I all so do not use the diff oil I use the spring kit HPI makes.
RE: mt2 diff
sorry posted in the wrong forum. admin could you delete this post from me. thanks
| All times are GMT -8. The time now is 09:17 PM. |
