Nitro Cleaner
Nitro cleaner smells exactly like automotive / motorcycle carburetor cleaner. Is it the same?
RE: Nitro Cleaner
Probably. Just look on the bottle to see if it says if its safe in plastic, or anything else on the car. If it is try it out.
RE: Nitro Cleaner
Some of the cheaper carburetor cleaner will leave residue like WD40 does. And the good carburetor cleaner might eat up your plastic or damage the electronics. To me, nitro cleaner doesnt smell nearly as volatile.
RE: Nitro Cleaner
Congrats on first post Adam.[8D] Thats why you want to MAKE SURE it says safe with plastic. You shouldn't have to worry about electronics because you DON'T GET THEM WET unless sealed. If it doesn't say try it on something else first.
RE: Nitro Cleaner
This is what I use and you get about 3 times as much for less. You can all so use denatured alcohol. I will probably go to that next as soon as I user up 4 bottles of Wild Cat I have.
http://www2.towerhobbies.com/cgi-bin...&I=LXWC47&P=ML |
RE: Nitro Cleaner
I use brake cleaner from autozone works just as good.
| All times are GMT -8. The time now is 11:38 PM. |
