Fun Factor
I have a cen fun factor. When i try to accelerate as quickly as possible it just stays ther and revs up. Then when i let go of the throttle gently it starts to take off. What is wrong
RE: Fun Factor
hello READ THE MANUAL THAT CAME WITH THE TRUCK LUKE FEEL THE FORCE read up it has mucho info
RE: Fun Factor
Check the slipper clutch, or check the diff screw if it has a ball diff. I'm not real familiar with this particular rc so it might have a ball idff and might not have a ball diff. Those two (again if your truck has a ball diff) will be two things that would cause this. Check to see if the slipper is loose, or the diff screw is loose.
RE: Fun Factor
How old is it? I would say check the clutch shoes and like stated above the Ball Diff if thats what's in that truck. I had a similiar problem with my Evader and it was the clutch shoes were worn down.
| All times are GMT -8. The time now is 01:28 PM. |
